A TCAM hardware operation failed. The specified TCAM entry's statistics could not be cleared as a result.
Try rebooting the associated I/O module. If the problem persists, run diags on the I/O module. If that passes, gather "show tech" output and contact technical support.
Error
TCAM write entry %index% failed (card num %cardno%), ILM %ilmInst%
| Name | Type |
| index | xInt |
| cardno | xInt |
| ilmInst | uInt |
